OBD 1 injectors on OBD 0 car?
I've been looking around on the net for info on this and the general consensus is that you just need to solder the wires from the resistor box and dremel out part of the female end of the plug to allow the obd0 male side to slide in. BUT! I legit cannot find any pictures that i need to use for a guide can anyone post a pic or tell me on this one what wires to solder together , and will i run into any issues when i go to smog my car because of this?
my injectors stick causing my car to run rich which was a hassle last smog test but i passed and im just trying to get my car running like a top and of course get a little better gas mileage considering im just running raw fuel out the tail pipe at this point!
i searched but nothing really screaming obvious answer in here so i figured id just post this and get to the bottom of it real quick lol.
heres a pic i found of the different plugs. Obd 0 on left obd 1 I want to say and the old 1 dremeled
found this but i dont get it as ive never done anything with these parts of the harness before.
Sonictronic wrote: »Use a 92-95 civic power distribution block like this:
Just depin the whole distribution block and your resistor box and put the 4 red/blk wires and 1 yel/blk wire into the distribution block in any position. That will just send 12v power to the injectors when the ignition is on bypassing the resistor. That way there is no splicing. Only do this when using Saturated 12ohm injectors. If you install some peak hold 2.5 ohm injectors like say...dsm 440s then you need to put the resitor back in.
BTW: There is no need to replace the obd0 injectors if you leave the resistor box when doing an obd1 swap. Just use the Obd0 injectors in the obd1 motor regardless of ecu.
Now you just have to make the plug fit like you said, so you can dremell that or attach the OBD-1 Plug to the OBD-0 Loom.
This is a must do for anyone looking to go for a bigger injector as the OBD-0 options are very limited.
When i put the OBD-1 Engine into my OBD-0 Car, I chose to stay with OBD-0 Injectors and loom, with resistor box.
First off I'd try putting some marker per on the OBD1 Injector Male and fit it into the OBD-0 Female and dremmel anywhere that has ink?
or a second opinion before swapping the injector wires over but that was my plan
Try a few other ways before chopping them etc.
im gunna dremel over swapping plugs over because its less cutting of the harness which im already sketched out about...
This is a quote from a post called using old 1 getting rid of the resistor box or something like that https://www.civicwagon.com/showthread.php?13152-getting-rid-of-the-resistor-box-and-using-OBD1-injectors
finding more and more info
So is this the side i cut and solder all the wires together?
then do i just need to grind down the parts of the injector to allow obd 0 plugs and im set?
ima dude. -____-
here you can see the obd 0 injector has a line down the middle of the plug
the plug shows voids on either side which use the two lines as a guide or track ( completely unneccesary )
here you can see there is no line down the middle but there is two lines at the top of the plug , those are what we will dremel out.
heres a ground down aka " modded " obd 1 injector
i used a very thin dremel attachment
" if it clips, it fits "
success the injector is now ready to be matted to my obd 0 harness!
upon inspection of the obd 0 injectors i noticed one of the hats was stuck in place this could be the cause of my raw fuel and rich running smell thru the exhaust
cleaned out the seats
theres a second ring in there that has a lot of carbon build up i just left it im not sure of any negative effects it can cause considering it should be a air tight fit now
better pic of the build up
nice clean o rings
all injectors inline and installed
now for the fun and scary part
mutilating the resistor plug wires
sorry harness
prior to cutting i sectioned off the top row of wires and the bottom row incase i want to reattach in the future for whatever reason that may be..
just going to store them with the old injectors
all stripped !
bought all this stuff a few months back only gunna need one small piece of heat shrink but i think i may tuck my engine bay so this will come in handy later on
soldered up real good
left with a nice clean " cap "
money shot , fired right up no more rich smelling exhaust and hopefully no more leaks or random misfire from flooding .
it may be the placebo effect but i swear the throttle response is enhanced my old injectors probably had around 300 k on them so who knows!
any ways. thanks for the help everyone that chimed in , now the internet has a hosted version of this write up
