Kate: new girl on the side
Charb
Administrator
New EE in my life... 91 5spd w/ a/c
Supposedly 'lost compression' but was parked and left for dead. Tags say 2003. I'm seriously doubting it's been sitting that long, but didn't have time yet to look for registration or anything. It was sitting in some guys driveway for a while at least.
Bill picked it up thinking he would get it running. But decided to sell it to me. He made some moneys, and I got a super clean shell for a good deal.
Ideally I'd like to keep both of my wagons. Really depends on what it takes to get this one up to daily driving standards. I'm moving to Phoenix after Christmas, so this new one will be perfect for daily driver usage.
Big thanks to Bill for helping me tow it home too!
If it was 4wd this would still be in my garage... or at a shop being fixed... i just dont have time to fix it myself. time is money...
kidding. Looks RAD!
Congratsbon your purchase
You should see it now
Spent some time over the last couple days trying to diagnose. Started with the usual suspects. Main relay to start. Tested it in Nancy and it works. Then went to the ignition coil. Tested a little low. Supposed to throw a code, so I checked the ECU, and got no lights what so ever. Which, I should because I've got a check engine light.
Thankfully Brian (hondawagonsts) had an extra distributor and ECU, and was so gracious to drop it off while I was at work last night. Unfortunately, even after trying a different coil and a different ECU today, it still didn't start.
After talking to bam tonight, I realize I really can't overlook the possibility of it being a bad motor. BUT, I also overlooked the fact that I can't hear the main relay or fuel pump. So, in the next day or two, I'm going to try and find a compression gauge. Just so I don't waste any money on parts when I still need a new motor. Hopefully compression checks out, and I'll swap in a new ignition switch.
While sitting contemplating in the car, I noticed this oil change sticker. Which made me feel good when I looked at the mileage. Then made me feel bad after I realized the date LOL
There's only about 800 miles more on the odometer since the last oil change. Which confirmed what I saw under the valve cover earlier. Maintenance. Car was originally owned by a computer company in the Seattle area. So I'm still really really hoping it's not going to need a new motor (right away) lol
BUT, it confirmed my fear that the car had been sitting for exactly 9 years. Which could pose a handful of other problems. But I'm not going to get further ahead of myself...
Killed 15 minutes before work today...
A little Palmolive, some water, and a bit of elbow grease got me a whole new bay! Don't be skirred kids! Clean engine bays are where it's at lol
I've got an extra valve cover I'll probably paint up this weekend. Also hit the motor with some engine cleaner. Not much oil on the motor thankfully. But still want it gone
Ran out of time to put it all back together tonight. I need to thoroughly clean the inside of my tank. Hopefully have it wrapped up by the weekend.
because your's is not clean too......lol
Someday you'll understand our obsession with white...
Just busy with life. Been working six days a week. Then Sundays are my relax day where my buddies and I drink beer and watch football for ten hours. Due to light and cold temps I cant do jack when I get home from work. I usually only have 2-3 hours of daylight before work, and just haven't wanted to start tackling anything in that time (plus other things to do).
Today I made my first attempt at using electrolysis to remove the rust from inside my tank. Unfortunately it didn't work. I'm thinking my sacrificial piece of steel wasn't good enough. Also may be using the wrong battery charger. Was limited on time before work and had to give up angry lol I'm off Wednesday too this week, so I'm hoping to get a lot of stuff done. I've also got a handful of goodies to install, and some things to clean up should I need to occupy my time while she soaks. Fingers crossed I get this tank cleaned this week!
Here's my attempt (failed) at electrolysis. Though soaking for a couple of days did clean up the inside some.
Looked a lot worse in the beginning. I mean, a LOT worse. I've currently got a couple gallons of apple cider vinegar in it now. Gonna buy some more and fill her up tomorrow. Let it sit over the weekend then I should be pretty good to go.
I soaked my exhaust manifold heat shield bolts for 48 hours in apple cider vinegar. I was extremely impressed with the results. That's why I opted to do it on a bigger scale for the tank. I'll get some pics of the bolts tomorrow. I also painted the wheels. I'll snap some pics of them too.
panda wagon crew holla!
lolololololol
