Differences between the Manual and Power steering racks!
Here are some pictures of the differences, you can tell right away there is a BIG weight difference:
Here is the mount that has a different diameter. The Passenger side mount is larger on the power steering.
I used a Crx Si front rear subframe. From my understanding all EF's front subframes are the same. The only difference is if its power steering or manual steering, and then it comes down to that mount.
Great info. Did you get a new rack, or refurbed an old one?
I would suggest you keep looking for a power steering rack subframe or also change your steering rack to a manual one. If you were going the other way (putting a manual steering rack into a power steering rack subframe) it is simply a matter of making some reducer bushings and moving one bolt hole (this is what I did on my car).
Every time I go to order the bushing set it tells me it's for PS rack only.
I made a separate post about it before I found this old thread. Recently replaced my steering rack and the new one (a Maval - most expensive, assumed best quality) and the right side seal is leaking. Looking at changing to a manual rack. I think I could make a reducer bushing pretty easily (I was thinking PVC pipe sliced lengthwise) but which bolt hole do you have to move? Also saw something on the Honda-tech forum about needing a different steering coupler, is that true?
