Where to get OEM rear shocks? 91 RT4wd
I went to ORiely's and they gave me the wrong rear shock. They told me the FWD and 4WD shocks were the same. So I brought it home and it is way different than the ones I had installed.... any tips?
FWD and 4WD shocks probably are the same, but that ain't one. The higher position of the lower perch gives it away.
I would think that with the differential in the rear, honda would put a different shock on the RT...?
edit: and if anything were to be different, it would be the spring. Remember that the strut is only a damper.
viewtopic.php?f=8&t=4390
What if I only pu the EF rears and leave the front struts alone?
Would that be terrible?
