4WD Help
I found an '89 4WD but don't know much about them. I'm not into the rally thing and I have no real need for all wheel drive... I really just want to slam a civic wagon and was actually looking for a 2WD model. That being said it's the only one in my area at them moment and it's cheap. Before I jump in I want to know a few things. I'm hoping someone can help educate me on the differences between the 2 and 4 wheel drive versions:
Gear ratio differences between the two. Is the 4WD geared lower?
Can the 4WD be lowered as easily as a 2WD?
Advantages and disadvantages of 4WD and should I just wait to find a 2WD to lower (this thing will never see off-road)?
Thanks for any help, and I'm using the search feature as well :oops:
4WD has more things you have to worry about when lowering. Look in the suspension forum for more details.
Like what? I am low, and my buddy has a 4WD and his is slammed. No real problems thus far.
You will see lower gas mileage with the AWD. Im averaging 24-26 with a 29 high from all highway driving.
Running an aftermarket exhaust will be harder. You wont ever be able to do a B series swap and keep the AWD system. The shifter mechanism is WAY different than a standard 4th gen (cables, not linkage), other small things that might end up being more than you wanted to deal with.
I wish I had a 4th gen civic 4wd (I have a 3g 4wd, but the 1.5 75hp carbed engine is slow).
i got a clean 4wd ill trade you maybe. i just dont have a druve shaft and its auto
