91 suspension help
i still havent found a wagon yet but i was wondering if the stock suspension off of a 91 hatch would fit say 90-91 wagon? the reason i ask is i have a set that has tein springs on them.also did a little work to them to make the car go lower.
any help would be great thanks
josh
josh
BUT here's a little insight into your question.... You can use the front suspension off of the hatchback, but not the rear suspension. The wagon has different length struts and springs, so it will not work, even if you wanted to just use the springs off of the hatchback. You could put it together with the rear wagon struts and the aftermarket springs, but it would not sit anywhere near where you want it to.
You can use the complete suspension off of the hatch or a crx. Yes there are differences but I have a TEIN HA setup and a KSPORT setup off of a CRX/CIVIC and have had no issues WHATSOEVER.
