Which one? Under the rad, or at the steering rack? Under the rad, no. The bolt holes on the Wagon/hatch/CRX/sedan are angled from front to back (like this / \ ). The DA are parallel (| |). At the steering rack, I don't know.
at the steering rack. im looking at buying a wagon and the crossmember is broken. i thought about just welding it but my bro has a da integra laying around so i was hoping i can just use that one.
I think it does. However, if the Wagon you're buying is not power steering, the Wagon rack won't quite fit the DA subframe properly. It's not that hard to get it to fit, but you could always use a power steering rack with the subframe.
i will update to see how this all works out.
