CRX SI Brakes & Suspension on wagon?
I've searched but I cant find what Im looking for. Maybe I just missed it.. :roll:
Anyway, I have a 90 CRX Si sitting in my driveway. Im going to pull the rear arms and sway bar off today and also wanted to pull the front upper control arms. I know that aftermarket arms are the same but im not sure if the factory arms are the same. Does anyone know if they will work?
What about the front brakes? Would it be a worthwhile upgrade for my wagon? Can I possibly swap the whole spindle/assembly?
Thanks in advance
Thanks in advance
Si/Dx/Lx front spindles are the same as wagons
If you ever want to make sure things are compatible check out www.hondaautomotiveparts.com choose the car you want to check parts on choose the part and then add them to your cart. then look up the other, if the part is interchangeable they are usually highlighted already!! Otherwise add to your car and check out your cart to see if you have 2 of the same thing or different.
at least thats what I usually do.
a)MC(check size to make sure it's bigger than yours).
b)Disc Porp.Valve(if rear disc in case u want to convert to rear disc later).
c)the whole Rear disc (if it's r.disc) & r.swy.bar.
d)Front brakes(yes they're bigger)
I never knew this. Thanks for the info.
Swapping 4WD to CRX Si does nothing,BUT 2WD Wgn to CRX Si is a upgrade.
I didnt get to pull the brakes but I should get them next weekend
