Suspension bushings?
Which bushings do you prefer and why? Right now I'm concerned with Rear trailing arm bushings, but also need radius rods, swaybar, etc.
For new bushings in my RTAs: Urethane? Rubber? OE? aftermarket? What brand?
discuss.
discuss.
Lowering the car puts stress on parts of the bushes that they were not designed for.
On my Shuttle RTi i put Noltec blue urethane RTAs. Worked awesome, kept the car flatter etc.. Previous ones were poked as though.
So mainly i say if you live where the roads are like glass then go for it, poly on. Otherwise i say go rubber/oe.
Why, because of the squeaky poly noise? The roads here are fair, but I regularly go to the mountains to play. It's not at all unusual for me to get airborne on the fire roads.
I read somewhere about some of the polyurethane RTA inserts "walking" out. Anybody seen that?
With regard to the lowering and OEM rubber bushings, if you leave the fasteners loose when you install the bushings, and then put the weight of the car on the suspension at your expected ride height, and then as a last step tighten the bolts, you'll have the rubber in the bushings in a relaxed state at your set ride height, and this will cause no undue stress on the bushings. When it some to the RTA bushings, you need to predict or measure what angle the center steel bar needs to sit at before you press it into the arm so that it is very close to the correct position in the arm for your ride height, or you will be stressing the rubber in the relaxed state, and this will lead to premature failure of the rubber.
