(shx & bushing) questions
First I've searched and read a lot of articles about wagon suspension. The problem is that those articles always focus on lowering the suspension.
I've got an '89 RT4WD with stock (and worn out) shocks. I need to replace them but I do not want to lower the car. I can handle the car going up a little, but not lower. I would like to use my stock springs with a performance minded shock. I can get Monroe Sensa-tracs but I'm not sure I want to go that route...
Any recommendations?
Also, at the same time I'm probably going to replace bushings. Do the poly bushings work well or should I spend $$ for Honda bushings?
Which bushings?
Monroe use to have a hi-perf. shx,but I don't see it any more.This is what I heard about the Monroe Sensa-tracs...nice ride,but soft cornering...don't last long...
What's your budget?The best =Koni($500),the other's about $300 and less for the second tier shx.
I'd like to stay somewhere around $300, but I don't want to spend $300 on junk when I could spend $500 on something good. I've looked at Koni's but didn't think they made anything for the wagon.
viewtopic.php?f=8&t=4390
Goto the lowering section under 2-3''.Read the 1st sentence.You'll be using EF rear springs instead of lowering springs.
I'm not a big poly bushing fan.Hard to put in,noisy&hard riding.Money better spent else where like a rear sway bar(more info @ above link too).Bushings to me rank at the bottom of the suspension upgrade list.
I would love to spend the bushing money elsewhere, but unfortunately after 200,000 miles the bushings are getting a bit worn and need to be replaced.
If it helps any I use my wagon to haul bikes, kayaks, camping gear, etc. I bought it because of the AWD to get me to and from some of the places I go. That's why I don't want to go lower. I do appreciate the ability to go around corners though so I want decent shocks.
I, too, am interested in improving the handling without lowering the car. My RT4WD is my winter daily driver, and occasional rallycross car. Performance shocks do seem to be the answer - won't bump me out of stock class, either.
If you come up with any, please let me know.
