Removing and replacing rear struts on '90 wagon
The process seems pretty straitgh forward so I want to replace the rear struts myself. I also want to replace the bushings on the trailing arms.
I know I have to jack up the car and secure it before I remove the bolts holding down the struts and the trailing arms. The workshop manual adewuately details this process.
However, don't I have to do something to the springs so they won't come shooting out or does jacking up the car remove the load on the springs?
Can anyone describe the process for me??
Thx !!
Thx !!
The spring and shock should unbolt as one and you will need to use a spring compressor to remove the spring from the shock.
the trailing arm bushings are fun! May I suggest using a torch and burning them out. Replace them with something nice like ES. They are the same bushings from all civics.
Concerning the bushings, a fellow car hobbyist who owns a '52 Vauxhall is going to show me his method for removing and installing bushings using a C-clamp... but burning them out sounds like fun !!
Hondas official method is to use a rubber hammer.
Take trailing arm off.
Burn bushing.
Eventually bushing with catch fire.
Walk away.
Repeat until you can get the rest of the rubber off with a wire wheel (motor driven).
I took my trailing arms to the local mechanic up the street, to have them pressed in and out, among some other work to be done to them. He gave them back to me in the same state that I gave them to him. Said he couldn't do it. More like he didn't feel like doing it...but you get my point.
also I severly doubt you can warp a trailing arm by using a standard automotive torch (can't remember the name of the gas, not map gas!)
I actually just called the service dept and they told me this over the phone.
I'm a bit of a fire bug myself but only when it involves things that are meant to burn and I don't risk burning anything important... like my Honda...
I think I'll try the C-clamp method and report on my progress...
Of course none of this will occur until the weather improves here in Fortress Arctic (aka Canada).
Cheers !!
you'll know when you see it... pain in the arse, i'd rather change the motor again than do anymore bushings.
