Integra Type R Coilovers
Would Integra Type R full coilovers work good on a wagon?
I realize that they would make the wagon ride higher, but if I purchased some coilovers that are adjustable shock length (stroke/ride height) would I be able to still lower the wagon significantly or would I be better off buying the koni yellow gc set up?
I know if I did the itr coilovers I would need 92+ civic shock forks and itr rear lca's if my wagon is post 1988.
Thanks in Advance
Adrian
Thanks in Advance
Adrian
USDM are fork mount but JDM are eye mount.
The JDM ones will fit but you need to grind a bit off the eye as it is slightly to wide, not sure about the front
I thought all itr were eye mount. I have some jdm itr rear lcas from my integra days so that won't be a problem. But the question at hand is will they lower the car enough, or even at the lowest setting will the car still be high.
I know that all JDM integra's are Eye, but USDM are fork?
WARNING: :twisted: DUK! Spam attack!It may drive you CraZy.It's a good article,but poorly written.You'll probably find your answer there.
I did search I read all the links I even searched on other boards but no one talks about itr full coilovers that are shock length adjustable.
Personally if your going to spend the money, get a strut with a shortened body. Youll be happier in the long run if you like to lower ride heights. Most of the more popular brands shorten the bodies around an inch.
