steering column going left to right
So today i picked up another wagon. The problem is if i grab the steering wheel and pull it left the wheel and column and all go's as far left as it can. it will not move to the right like that. and no play up and down. no play in the wheel and tight steering just the whole assy. will move to the left about 3 inchs off center and i can move it back center no problem. gotta fix this asap lol went around a sharp curve and almost lost it because for this.
caster and toe issues on ef's after wrecks are supe hard to diagnose
But here's my suggestion: check the bolts in the steering rack. I bought a sedan once that was missing those bolts, a
and your description sounds familiar.
Yep, there is a bent half-circle bar with 2 bolt holes that should mount the shaft to the dash bar. If it is loose or missing, the whole assembly will feel loose.
#4 in the pic >
I bet its the half bar. forgot about that thing, ill check it when i get back to town. the whole column moves to the left
