just wonder
ok so my friend owns a few accords and on his forum he was reading that EF upper control arms give negative camber here is the link http://www.cb7tuner.com/vbb/showthread.php?t=156512
so does the mean accord upper control arms could correct camber for EF when being slammed?
cause if so then i got some free uca from my friend. thinking about trying it out unless someone has a correct answer for me
that's what i was thinking. but if you look at that thread, and if he did use ef arms, the accord ones should also be bolt on. right? i think it may work, but i also think you will end up having positive camber which defeats the whole purpose. your fenders will not like you. still, i'd like to see it though.
I found a thread on Honda-Tech: http://honda-tech.com/showthread.php?t=2590492&page=2 (Ignore the bullshit on the first page).
There is no data for how many ° the camber is changed... If I would know the difference in the length from bolt to bolt, I could probably calculate it...
The number I'd start with is 1/2"(12.5mm) longer.You probably meant bolt to ball joint.
2 guys on the link say 4-6 degrees.S2's are 3 degrees.My ball park calculation is 2 degrees.
If you need further help let me know.
