Brake modifications for better coasting
While I've got this beast up on the jacks, I'd like to modify it for efficiency. I understand that, for most cars, there are two hardware modifications to be made: stopping the disc brakes from dragging, and better bearings.
Anybody know how to do do either of these things? (I just got 45mpg in my unmodified Civic Hatchback, and I'd like to be able to achieve similar with my Wagon.)
I just found that a "square o-ring" (oxymoron alert!) is used in modern cars to help push the calipers back a little when the brake is released. And to stop the rear drums from dragging, you can remove the self-adjuster... but then you have to manually adjust the brakes.
I'll be looking into the square o-ring, and testing my rear brakes to see how bad the drag is. After that, though, I'm going to give up and look at more important stuff.
But the wheels are off NOW. Brake and alignment mods are simple, cheap, and easy. And the last time I tried to spin the rotor without any connections, it didn't spin freely. If I can grease the bearings or something to reduce that drag, it would be helpful.
I checked the Hanes manual, but it didn't say anything about bearings. So I came to the experts.
you can get plenty of traction with them in bad weather
your ability to take corners fast will suffer but by lowering your car you should be able to carry more speed through more corners there by needin to acaelerate less in the long run
