lowering springs-hatch to a wagon?
wondering if the lowering springs on my '91 SI would be a direct bolt-on to a wagon? they're still on the shocks and struts. not sure what kind they were or what the drop was on them. they were on there before i got it. i know that they're not a direct bolt on for the sedans. obviously i don't have my wagon yet but i want to know before i get mine. i know i can take them off and then put them on the wagons shocks and struts but if i don't have to i'm not going to.
You actually have to use Civic rear shocks in order to lower the wagon, because the spring mount on wagon shocks is much lower than on a civic.
You can also lower a 93 Del Sol using stock wagon shocks and stock del sol springs.
and yes, the 88 has its benefits, like the rear struts. supposedly that set up is stronger, which is why they used the same style on the Integra Type R, except they were bigger in the ITR.
For instance, it's lighter, but it still has the same GVWR, so you can safely carry more stuff. And it still has the manual seatbelts.
