Fuel Saving Mods?
Heyo!
Gas is getting expensive again. I am convinced it will keep going up. Anyone ever done anything crazy to their cars to save gas? I'm talking in the same vein as this old hatch: http://www.aerocivic.com
I know about the electric wagon... That costs too much!
Any idea how much of a difference covering the rear wheels would make?
I know somebody that would trade you a crx for your wagon.
http://www.hondacivicwagon.com/bb/viewtopic.php?f=16&t=8083&hilit=fuel+mods+mpg
You gotta search though. New engine+trans+ecu would be best
That is quite possibly one the the most expensive ways of increasing your economy. Not to mention that as soon as its turbo you will want to drive it harder.
Best way to increase economy:
-clean your car out of rubbish, no point using your car as storage and carrying useless stuff everywhere you go
-check your tyre pressures, low tyre pressures will increase friction on the road
-take notice of your driving, when you start trying you will be amazed just how economically you can drive
The same principal applies to having a turbocharger.
Those prices are way off base. What parts would you be buying? Brand new HKS stuff?
I never said it was the cheapest or the easiest way to improve efficiency. But I did say it would improve fuel efficiency which was what the OP wanted to know.
I have another suggestion for improving fuel efficiency that costs about $3 and can be done in ten minutes. It is even tested and proven many times over. Tape off all the sharp edges and gaps on the front of your car and most of the opening in your bumper. You can't tape off the radiator opening entirely obviously but you can have a 6" opening and not overheat.
still might not be worth the fuel economy improvements, but it'd be a lot closer. and more fun.
LMK if anyone needs turbo stuff, Utah has dirt cheap used turbo kits lol
11:1 CR, D17 stroker, 4.437 final drive, Zex 59300 cam, Y8 intake manifold, Megan exhaust header, etc
39.4mpg cruising at 3700rpm. not bad at all.
anyone who wants better mileage that has a roof rack needs to take that shit off!
i need a roof rack and it will stay there if i ever find one. lol.
Tire pressure (like mentioned)
possibly a cold air intake setup
turbo charging it if you can get a good deal on a kit
i had a buddy put a msd coil and cap on his sedan and was getting about 45-46 mpg when he took it off and drove it and did a comparision he got about 39-40 mpg.
Something to think about ? maybe
Pretty sure thats super legit.
I think my friends mini-me gets about 39mpg and its pretty quick too. Totally a good option if you're down for the wiring/getting a whole new motor haha
the problem with most fuel saving mods gives you extra power, this make you want to use it and you'll use more fuel.
i've seen many turbo upgrades convert to e85 out here in ks., they say it works and plus gas is cheaper.
The other problem is water.Just a few drops( :twisted: Yes a few drops ) can cause the gas & alcohol to seperate.If you store your vehicle for a extended time even the current gas will eat your fuel pump.I stored my Fiero for less than a year.The current gas ate my new fuel pump.
The other reason E85 is cheaper is it gets less gas mileage.
Political statement:We CAN NOT use corn as a fuel.It competes with food production.The Corn they grow for fuel is different from the corn we eat.It taste bad.They grow less eating corn and other crops 'cuz the gov subsidies pay more.Remember the Mexican Mom's tortilla revolt.Even our food prices went up for this reason.Itwas covered up by the bad economy .
As far as this current gas spike.The answer is easy.All Obama has to do is sign in a Executive Order that all New federal vehicles purchases from this point on must be CNG.THe USA has more natural gas than we know what to do with.Did you know that when oil is pump out of the ground that that escaping natural gas is pumped back into the ground.
- tire pressure, if you don't care about ride quality, fill them to the max psi posted on the sidewall.
- air filter, fuel filter, plugs, wires, cap & rotor
- don't turbo
- lighten the load, spare tire & stuff... ( i keep mine in, you never know)
- mpfi swap (if you haven't already)
- stay under 65mph
2 weeks ago I did a 4,500km road trip and kept very close eye on mpg.
- with wind @ 110kmh - 35mpg
- with wind @ 120kmh - 29mpg
-against wind @ 110kmh - 29mpg
-against wind @ 120kmh - 24mpg
-tire pressures were set to a low 26psi, winter driving conditions, studded winter tires. i would rather have good traction than have died trying to achieve mpg.
-had about 150lbs (or a passenger) worth of cargo.
-fresh alignment done at Winnipeg Honda. thanks dave.
there were enormous differences in mpg between 110 & 120. the wagon does not like battling wind and highway speeds.
After reading this thread, I decided to change my driving style for a tank of gas.
I used to shift around 3k-3.5k which netted me 30.2mpg
I changed to shift sub 2.5k, and cruised on the interstate less than 70mph. I netted 33.3mpg.
I was shocked needless to say.
more agressive driving + more agressive cam = better fuel economy??? lol
^^ He's right. On our recent Florida trip I got 20 mpg pulling the trailer on the interstate at 80. When I slowed down and cruised back north on A1A averaging about 50 mph, mileage went up to 24-5 mpg.
Of course, if every hour at 80 brings me 30 miles closer to home...screw the fuel economy!
Bone stock '94 S model, 144k miles, I haven't touched it. Gotta love it!
I'm thinking on building a mileagecentric wagon. Problem is my commute is 10 miles with 20 lights. Hard to achieve much. Maybe I'll just ride the moto- 55 mpg.
I decided to get the e3 plugs as well. Just to give them a try.
I also keep my tires at 36 psi.
I figured while I was at it I would change my driving style since I was now going from a 10 mile commute to a 26 mile commute.
My crx is basically stock. 88 crx si with 351k on the original motor. The only thing I've done is regular maintenance and put a true cold air kit on it and a free flowing monza "pacesetter" exhaust.
With that in mind. I changed my style from shifting at around 4k to 2.5k.
I keep my average speed to around 50mph in the city. Now I'm not on the highways. This is going through the city on city roads, so I'm usually 5 mph over.
I took my mileage up from around 32 mpg to 39.75 mpg just by doing those simple things.
Now with my EP3 I do the same stuff, have not changed plugs over. Just keep the revs down and I'm averaging 32mpg.
MY issue with all of this is I'm an engineer. Kind of stressful some days. Also granddad was Irish. I have a very short fuse.
MY stress reliever tends to be my right foot and 6k shifts so on those days I accept that gas mileage goes to hell.
'91 5 speed lowered on Skunk2 pro-S coilovers and low-offset 13x6 Ardun slot mags. Cheap tires @ 36psi. Volvo front lip. Stock otherwise including DPFI.
I noticed with the low suspension and a Volvo front lip my mileage went up ~4mpg. I drive pretty conservatively (usually shift around 3.5k), but not like a hypermiler.
I'm going to make a belly pan. Trying to hit 40mpg. I got 36 on my last tank. It's like a game now.. pretty interesting to see the little changes add up. I couldn't beat 32 when the car was stock, and that was driving like a retiree. Now I get better than 32 driving aggressively.
