RT4WD transmission rebuild
Hi All,
Im just wondering what are the options out there for rebuilding a manual 89 RT4WD gearbox?
As you can see you cannot get OEM parts due to them being discontinued
#8 & 9 discontinued
http://www.oemacuraparts.com/find-parts/Honda/CIVIC/1989/5DR%204WD%20%281600%29/KL5MT/MT%20MAINSHAFT%20GEARS%204WD
#7 shows as still avaliable
http://www.oemacuraparts.com/find-parts/Honda/CIVIC/1989/5DR%204WD%20%281600%29/KL5MT/MT%20COUNTERSHAFT%20%284WD%29%204WD
will these synchros fit the gearbox?
http://www.ebay.com.au/itm/Honda-1988-2000-Civic-CRX-D15-D16-Carbon-Synchro-Set-/170503551235?pt=Race_Car_Parts&hash=item27b2cdb903
also will i be able to use the FWD L3 gearbox synchro hubs + gears?
If there is a thread out there already discussing this then please close this one
thanks!!
#8 & 9 discontinued
thanks!!
Thanks ill try and find it, i did do a few searches but nothing promising came up. I Also tried some of the driveline quicklinks but they dont work since the forum has switched.
I had a look but could not find it, do u mind posting the link? Thanks
crunch 2nd sometimes, everything else is good. no bearing noises. Maybe its a issue with the shifter cables, stretched?
any other options out there apart from this one?
Also does anyone know if these fit?
It says fits gearboxes marked L3
I might be getting my hands on a rebuild box soon from a wrecking yard, so i might have a shot at taking my old one apart and possibly comparing it to the FWD L3 box.
Any more info as to why they wont work FakeJDMEF8?
Id kill for some concrete info. As I'm sure you all would as well. My trans only grinds downshifting from 3rd to 2nd if I don't finesse it....
About to install the short shift box and mess with the cables, so we will see
How did you go?
Ive since replaced my gearbox oil and added an additive to help shifts, it hasn't been grinding since
I will still look into getting a rebuilt box when i change the engine over.
Anyone have any more info on the rebuild of the cable awd trans?!?
#3
http://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=18SH501&block_02=M__1500&block_03=9327
It's not cheap though
and the synchro kit for 2nd can be purchased from
#7
http://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=17SR401&block_02=M__2500&block_03=15098
hope this helps out some people.
http://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SR401&block_02=M__2400&block_03=15098
From what i have heard they are RT4WD specific but i cant confirm since i have never physically compared
