OBX Header Fitment
I recently purchased a OBX 4-1 Header for my RT4WD because my stock exhaust manifold was in bad shape. However, when I finally tried putting it on it will not clear the Radiator and hits the fan on it. Has anyone else had issues with this? In order to get it to fit, it looks like I'm going to have to do some type of modifications to get some more room. BTW this is on a 92 SOHC ZC engine. Any help would be appreciated.
Thanks
Thanks
1)Used a Honda 4-2-1 header w/a fabbed 2-1 adapter.
2)Used a Honda 4-2-1 header from a later Civic.I never did figure out what Civic he got it out of.It was some1 on this site.
The manifold is 4-2 and the collector is 2-1. What you can do is take the DOHC ZC 4-2 manifold and the SOHC ZC 2-1 collector if you want to run a 4-2-1 setup on a DOHC ZC in an RT4WD, without pissing around port-matching or re-welding the collector.
Alternatively if you run a SOHC motor you could just use both pieces from the JDM Shuttle RTi and you will have a 4-2-1 system, albeit a 'stock' one.
I think that member did it w/o ZC parts.
Thread is about a stock RT and the same header you want to get. Nobody knows what radiator or fan you have so nobody can help. Sorry, kinda obvious.
Sorry I wasn't clear. I stated i had a different rad fan setup because OP mentioned his fowled the header. The radiator and fan is not my issue, i want to know whether the OBX header that OP used cleared the stock RT transfer case.
I'd trust that guy for sure!
