90 dx wagon sputter?
so.... 1990 honda civic wagovan 2wd automatic
i head to my parents house to work on the brakes. the car would sputter a bit as soon as it got into gear. i figured, spark plugs and wires since i just got the car and thought it would fix it. after stopping off at advanced auto parts, i head out to th house and the car sputters so bad it felt like i was adding gas one drop at a time. i finally get it there and tried to locate the problem. as i start messing with the idle valves, i have my buddy in the driver seat, i have him turn it off. as it is shutting off the auto trans fluid line popps off and spills the nice blood red fluid all over my shop floor!
what causes the sputter, pulsating idle, and shift hard?
i have no CEL's
the timing is right
spark plugs are good
main relay is good
now the car turns over once and cuts off.
With no MILs, look for the rudiments- fuel, air, spark.
bam-bam; yeah im back, he doesn't seem to want to trade back. i took apart that diaphram and cleaned it and put it back together. nothing. now im trying to find out where the hoses go because some of them were cracked and nasty and some,... well i forgot where they go. i got home with a new spool of hose and couldn't remember what conncets to what!
ps, this car looks like a shady mechanic had the car and got it running for little effort/time. i found one of the 2 missing intake screws that had fallen between the starter motor and solenoid. i might be chasing my tail with this issue but i'd rather get it working bc i really want this to be my dd!
i need a gas tank, fuel pump, and sending unit!
what gas tanks are the same as the wagovan?
bam-bam, i'd be willing to buy it from you if you'd ship it but if you dont want to do that, dont pull it unless you feel the erge! thank bro!
USDM RT4WD and all JDM injected ones have this.
It'd be easier to drive up here and get it, no?
thanks for all the help
pm'ed you my number.
1) is this common?
2) what is the remedy? (replace or fix the one i got somehow)
3) does anyone have one for sale?
PS. i also have am sti;; trying to locate the fuel pump not priming issue. i replaced the pump and main relay but i cant seem to find out why its not getting the signal to prime. it is hooked up to the ignition wire off the cd player now and is allowing me to get it started that way.
2. You can clean them, a search will provide you with the details.
3. I might, pm me if the cleaning doesn't work. Part is usually around $200 or more new.
