Premature front tire wear on RT4WD
                    hello everyone.  i need pick your brains regarding my 88rt4wd front tires.
it wears prematurely.
im running 205/50 R15 on both front and rears. the car shakes at around 70 mph and its not due to tire balance. i know how unbalance tires shakes. after the front tires were cooked, i replace them with 195/50 R15. i thought that the front tires spins a little more faster than the rear. i observed that the fronts are wearing prematurely again. i thought that my viscous coupler is locked as if i have a straight drive shaft all the to the rear pumpkin. i though that the VC is supposed to act as some sort of a center diff.
i am really in need of your ideas. thank you very much.
wagon.................4ever................
how do i know or test my VC is still good or not. i will disengage my 4wd drive for now coz im killing the fronts so quickly. i need to study on how this is happenning. but if you have other ideas pease let me know.
thanks again.
wagon...........................4ever........................
Anyway, the first thing I would've done is just rotate the tires and see if that helps. But definitely get the same size on all four corners.
when i was running all 205/50 R15 thats when there was a shake. when the fronts are 195/50 R15 i didnt notice anyshakes but theres still that premature wear. the wear is even across the threads on both wheels.
thanks again.
wagon.........................4ever.........................
wagon...............4ever......................
