Automatic Transmission Shifting?
My 89 Civic Wagon I put Amsoil into the tranny thinking I would extend its life. Can anyone tell me how these cars shift and at what speeds up and down. I get a jerking motion when it shifts. Is this normal? Should I go back to the regular fluid or keep the Amsoil in? What other things can cause a shifting problem. Someone said it could be a solinoid. Is it best to check the fluid hot or cold? What do you think? Thanks! Any and all help would be appreciated.
see if that helps.
2.5 quarts(about 2.4 litres)?
viewtopic.php?f=7&t=4949
if that is a fact, you can look further into solving this "problem"
The speed (vehicle and engine) at which it shifts is entirely dependant on your driving. At full throttle, it'll run all the way up to redline before shifting. Part throttle, somewhere in between. And on my RT4WD automatic, it also depends whether I'm running in D or S/S4 (a setting FWD cars don't have).
I'm not sure what you mean by a jerking motion. This isn't the smoothest shifting automatic I've ever driven, and it's a bit more harsh in S (intentionally). When my trans was leaking fluid out one of the axle seals, it would start jerking rather than upshifting when it was low on fluid - a condition that went away as soon as I refilled it.
I've heard that Honda ATF is the way to go. Me, I've been using a generic Dexron III. I didn't want to drop the money on the expensive stuff while it was still leaking out.
