rt-4wd LSD
                    I was looking through the stickies and I came across a topic on a JDM lsd for the rear diff on our wagons BUT the link to the topic was broken.
I would like to get a little more info on this if i could.
LSD
A)OBX LSD.It's a well built LSD believe it or not,BUT you'll need a
'88-89 Si(orEX) tranny.And it's half the price of other LSD's.
B)4WD:There's a JDM LSD,but it's for the rear.Click on link for more
info: viewtopic.php?t=595
C) :!: Very Important!Make sure you upgrade your spare tire to the
same height as the front wheel unless you want to destroy the LSD.
The 2nd choice is when you get a flat.Put the spare on the
rear.Take the rear wheel & replace the bad tire in front.This will NOT work if your rear tire is NOT the same height as the front's.
But I would still like some info on it regardless
does your car lack rear wheel power? seems like from a dead stop in alot of snow, the car takes a second to move, like the front wheels are doing the most work...
The INTRAC rear diff isn't actually that much bigger, the diagrams exaggerate it a bit. Basically it has two viscous couplers built into it, one to handle power from the drive shaft and another to output power to the rear axles. It is both viscously operated and also via solednoid. Which means you can leave it RT4WD and then also push a button to force fulltime 4WD.
I had the Shuttle launching sideways at 7k RPM quite a number of times.
I would suggest having a read through the Quicklinks threads at the top of each page as it has alot of useful information in it, like the INTRAC specs.
You asked about rear LSD, i told you about it and gave you the link to read up on it.
Remove the Viscous coupler and you will have All time 4wd. Has anyone figured what the split is at the transfer case or is it the viscous coupler that does the torque transfering?? Maye I should read up on this :oops:
Next is the shimming of the diff in the housing. It needs a few more shims as the overall width is a little less. Guess what? Honda discontinued the shims. I was able to find a small assortment of CRV transfer case shims that are very close to the same size, and will fit perfectly. I also now have a "couple" extra diffs, and will be able to use the shims from those.
Otherwise, the Wagovan bearings fit the OBX diff perfectly, and the Wagovan axles and splines fit for the driver's side axle only. The passenger side axle needs a shorter spline (like a FWD axle), as all the FWD diffs have a shorter seat for the axle/spline. I will be using Civic FWD inner joints as well as Civic/Integra outer joints with my DSS custom length axles, as the total output of my engine will be going to the back wheels.
EDITED FOR CHANGED AXLE INFORMATION
Link to the fixed link:
viewtopic.php?f=7&t=595
Chances of this actually happening are quite low unless you're intentionally doing something idiotic.
No i said the topics should become searchable over time (which still hasn't happened after rebuilding the index twice so i'll have to look into it). The links will never fix themselves.
any input is greatly appreciated.. thankyou guys
jaker can i pick your brain. i got this premature front tire wear and im thinking that my viscous coupler is stocked up. when i put the car on lift and turn the drive shaft from the front side, the backside turn as well. is this normal? i was expecting that when turning the front wheel the rear wheels will not turn unless the VC will build up heat to locked up. please share your wisdom or somebody to shed light on this issue.
thank you very much.
wagon..........4ever.......................
thanks for the reply. and yes 4 wheels are of the ground and when i spin the front wheels, the rear wheels spins also. so thats normal. i thought the the viscous should spin freely. anyways. i thought thats the cause for premature front tire wear. ill try to check again my alignment and check if this is the culprit.
thanks again bro.
wagon.............................4ever........................
All four wheels are off the ground. You turn the front ones and the back ones aren't being turned, therefore there is a difference in rotation speed between front and rear, therefore the rear wheels start turning as the VC sends power to them, because of the difference in rotation speed.
