car is now whistling
                    so i adjusted my idle a bit, turned the screw only 90 degrees, and my intake now straight up whistles. LOUD. literally sounds like a bird is in the car hahaha. but its only when i tap the gas a certain bit and of course when i accelerate. its kinda funny in a way (i can drive by girls and tap the gas, voila... gets their attention hehe), and i find it amusing, but my question is, is this a sign that something is bad under hood by any chance?? or is this bad for the car..?
i only adjusted the idle because i changed my throttle cable for an Si one (i havent done that since my MPFI swap) and it put it ever so slightly off. anywho... oh and btw i have a cold air intake.
or Unplug IACV when car is at operating temp and running, adjust screw until you can estimate the RPM to be +-750 (make sure you do this with your lights on our your heater at full blast), plug IACV back in with car completely off, remove the Hazard fuse from the engine compartment fuse box for 10 secs or so to reset the ECU. Restart car and enjoy! 8)
i know this sounds stupid, but is it bad that the screw is too far out?
(i kinda like this new sound :oops: ) damn kids..
whenever i would unplug the EACV the car would instantly die. so i did everything without that, so basically i did nothing haha. the screw is almost on the max tighten setting, as any other way the idle is too high. its like a 1/4 turn (90 degrees) from being the tightest.
anyways, still whistles
thanks for the tips though!
I had the same problem 5-6 years ago, I had alot of carbon buildup behind the butterfly on my throttle body. It would slightly stick and cause a tweet or whistle, I noticed the buildup after running a short-ram for a year or so. I removed it and cleaned it all up, peek in there and let us know.
