Affordable way to increase compression!
                    this has got to be such cool idea.
All it takes is some .50 coins (or aluminum plates) and some JB weld!
http://forum.miata.net/vb/showthread.php?t=308510&page=1&pp=25
I really hope it works for the guy. Me perosnally I just see tommany balance and logevity issues, but ver cool none the less.
Don't do it!
Mabey flycut the head, run a thinner head gasket. Mabey a different oem piston that you could get fairly cheap will bump the compression?
I know there' pistons that interchange with the b series engines, but not sure with the d series.
there's a lot of science that goes into the design of a head chamber. I know there's a lot of tuning done by changing chamber dimensions on 2 stroke motocycle engines. Really slight changes can cause a lot of good, and A LOT of bad results. I'm sure a lot of the same theory applies to 4 stroke engines also.
