Wagon Dead...new issue
                    Lets see, how do I start this off....well here we go.
Earlier tonight I drove over to the gas station before heading off on a trip.
i put plus gas in the tank, full.
roughly 23 miles away going 55mph my car starts to act funny, I give it a little gas, and it almost acts as if it's out of gear, then i try again, and the car cuts out on me completely!
well I pull over and try to start back up...to no avail has it started up, I had it toed back to my house...
here is a video
http://www.youtube.com/watch?v=x6cAtRi5E_w
What you may not be able to hear is that there is a slight "thurrp" sound every few turn overs...
Any help or comments would be awesome
Thanks!
here is a video
Thanks!
Once you have the valve cover off and IF the belt still intact. I would crank it over a fiew time and look and see if the arms and camshaft is moving. If not its a broken cam shaft= Dead Head.
But looking at the Video there was a ping coming form the motor and that does not sound good. That could be a valve clinking on the piston.
But this is my best educated guess.
The belt in my 89 Si hatch let go in 3rd gear at 7,000 rpm once on an on ramp to the freeway. I had it towed home, changed the belt and was back driving wihin 2 hours. I was a courier at the time.
Yes, your timing belt may have broken, but it may also have lost some teeth. This is what happens a lot of the time. You'll take off the valve cover and timing belt covers, and find that the belt "looks" to still be intact. But where the timing gear is down at the crank, there'll be about 4-5" of belt with no teeth on the inside.
Before you lose your mind thinking that your motor is FUBAR, put a new belt on and make sure it is perfectlty lined up/timed and try and start it. If your water pump has lots of miles on it, change that while you're in there. If you don't chances are you'll have to start the whole process over again in a couple months when the water pump starts leaking.
Have a good read through this thread before you start working on your belt if you think you'll need any guidance. Its full of good advice on this process:
http://www.hondacivicwagon.com/board/vi ... php?t=3968
and this one:
http://www.hondacivicwagon.com/board/vi ... php?t=4407
=\ now i either A. part it out, or B. Check the head/valves/block for damage.
or C. engine swap (wich i dont really have the money for)
But... sometimes you get lucky. You can pull the head off and see if all the valves are seating properly.
its worth a try defenitly go with the cheapest route first always, hence you can use these parts at a later time, you have nothing to lose by being thifty, also it helps you learn diy projects one thing at a time. and dont forget the water pump,
how did this particular story turn out anyway?
which reminds me, i need to get the photo's up of project suzie. she's running!
(91 ef hatch)
Good luck with yours.
