2WD to 4WD Conversion.......
                    I found a wagon at the local salvage yard here this morning.  It has most of the 4wd parts on it still.  I am venturing back out first thing in the morning to pull everything.  Is there any big issue with converting a 2wd to 4wd? I did a search, but nothing really significant came up.   I figured it would be a mostly bolt-in deal.   I will be pulling the trans, drive-line, and complete rear-end out of the other car.  Also, can I bolt the trans to my original d15?  The motor in the car has been messed with.  So I am not going to pull it. What else do I need to know?  Thanks guys.
here is a link for you.
Gas tank is the same. I have one from a 4WD here, and it's identical to the one on my 2WD. You're right about the oil pan though.
