Auto trans trouble
I have a 91 rt4wd with an auto trans. Recently it has a delayed shifting problem. Mostly in lower gears. From a stop it will accelerate and rev up to over 4K before it will shift. Also, when slowing down from higher speeds, the engine revs up and down until I come to a stop. I just replaced the iacv and it didn't change much at all. Any help would be great. This is my daily and I drive 100 miles a day so I need to get it fixed
However curiously, I do have a 91 auto RT4wd trans that I will be selling. It was my fathers and has 133k miles on. Shifts perfectly. Keep it in mind!
It is entirely possible that the issue is in the module, however obviously you want to check the simple things like fluid and making sure that you're not slipping in every gear or is it just out of like first into second. The only first into second would at that point sound like bad friction Rings or something in a basket internal to the tranny. Another big important thing to check is the kickdown linkage that goes from the gas pedal and it connects to the transmission on the automatic. That one generally doesn't get touched unless the transmission has been removed from the vehicle. Another inexpensive thing to check because of the fact that the Hondas have external solenoid for shifting gears would be to remove the solenoids from the transmission check the screens at the solenoids and verify operation of those solenoids then it's cool putting it back together to get new gaskets and know that you're not leaking there.
