D16y7 with rt4wd oem??
Hi. Im looking for my engine option for my winter swap. I found 2 engine with 4wd tranny bolt to. Since my tranny have around 230 000miles, and she grind a little between 2 and 3 when high reving. And there is whining sound that i suspect is from trans.
Anyway. I think it would be nice to put a tranny with i supposed less mileage. My question is: do you know if there were d16y7 coupled with 4wd tranny? If no, i would suposed that this engine was to replace an older/blown motor so it may have a lot of mileage.
There is also one with a soch carbed zc (i would use the injection parts of my existing a6 instead of those carbs).
Link to both engine=
http://m.ebay.ca/itm/96-00-HONDA-CIVIC-DEL-SOL-ZC-1-6L-SOHC-OBD2-NON-VTEC-ENGINE-5SPEED-D16A-D16Y-4WD-/252397256684?nav=SEARCH
http://m.ebay.ca/itm/88-91-Honda-Civic-Crx-EF-Non-Vtec-Engine-ZC-Sohc-Engine-ZC-Dual-Carb-Engine-4WD-/311589396276?nav=SEARCH
