Installed custom exhuast on 1991 RTAWD Wagon
Sorry if this isn't the right place to put this I just wanted to share my experience of getting a modified exhaust put on my 1991 RTAWD civic wagon. I ended up using the axle back portion from a 91 ef hatch back. As a FYI the hangers had to be cut and new ones had to be welded to the muffler in order for it to hang correctly. Also we had to shorten the back section of piping to make it fit correctly, I am talking about the portion by the LCA. All that I added in line was a thursh resonator, just like a cherry bomb. She is a bit loud but I like it. Just thought id share my experience since this topic comes up quite often. After the pictures are a link to what it sounds like. Every other D series with a exhaust. haha its a stock d16a6 btw.
https://youtu.be/n2vpoI7knvE
https://www.youtube.com/watch?v=n2vpoI7knvE
Otherwise this is just standard build thread fare.
Regarding the exhaust itself, where's the flex joint located at on yours?
I will say, that resonator looks familiar.
Either way, I like your setup, sounds good. Though one thing to note, never film vertically.
I had to get a long bit of flex because the ill fitment of the header I put on. It doesn't tuck up under the oil pan as nicely as I'd care for it to. That said when I build my own downpipe and turbo manifold I plan on welding some stand offs and fabbing up a heat shield around the exhaust under the oil pan as well.
