Vacuum
I just bought a 87 wagaovan had a ford carb on it but the car came with a seperate engine when i put that carb on it and connected and blocked all of the vacuum lines it starts fine but it revs up and holds between 4 and 6 grand all i can do stop it is cut the car off i need help
If you start it up and cover up the throttle body completely, does it die?
