OBD-0 codes
so i was doing research one here on obd-0 codes and couldnt really find anything or maybe i wasnt looking hard enough so i googled it and found some info so i copied and pasted from honda-tech hope it helps people
0: ECU
check the ECU [FONT=inherit !important][FONT=inherit !important]electrical [/FONT][FONT=inherit !important]connector[/FONT][/FONT]. if no loose connectors are found, have the ECU diagnosed by a dealer service department or other qualified repair shop.
1: Oxygen Sensor "A" (Primary)
defective [FONT=inherit !important][FONT=inherit !important]circuit[/FONT][/FONT] or unplugged / defective sensor
2: Oxygen Sensor "B"
defective circuit or unplugged / defective sensor
3: MAP Sensor (Manifold Absolute Pressure)
4: CKP Sensor (Crankshaft Position Sensor)
5: MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
6: ECT Sensor (Engine Coolant Temperature)
7: TPS (Throttle Position Sensor)
8: TDC Sensor (Top Dead Center)
9: CYP Sensor (Cylinder #1 Position)
10: IAT Sensor (Intake Air Temperature)
12: [FONT=inherit !important][FONT=inherit !important]EGR[/FONT][/FONT] Lift Sensor (Exhaust Gas Recirculation)
check the hoses, the EGR valve lift sensor and the System EGR valve.
13: BARO Sensor (Atmospheric Pressure)
14: IAC Valve (Idle [FONT=inherit !important][FONT=inherit !important]Air [/FONT][FONT=inherit !important]Control[/FONT][/FONT])
15: Ignition Output Signal
missing or defective ignition output signal
16: Fuel Injector System
defective circuit or unplugged / defective fuel injector
17: VSS (Vehicle Speed Sensor)
19: Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20: Electrical Load Detector
21: VTEC Solenoid Valve
22: VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23: KS (Knock Sensor)
30: Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31: Automatic Transmission Signal "B"
41: Primary Oxygen Sensor - Heater
check the heater for the proper voltage signal.
43: Fuel Supply System
check the fuel pressure, fuel pressure regulator. check the oxygen sensor. also, check for vacuum leaks.
45: System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48: LAF Sensor (Lean Air Fuel)
54: CKF Sensor (Crankshaft Speed Fluctuation)
58: TDC Sensor 2 (Top Dead Center)
61: Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63: Oxygen Sensor, Heated - Sensor 2 (Secondary)
65: Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67: Catalyst [FONT=inherit !important][FONT=inherit !important]system [/FONT][FONT=inherit !important]Efficiency[/FONT][/FONT] Below Threshold
malfunctioning or defective catalyst system
70: Automatic Transmission
malfunction with the automatic transmission controls
71: Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72: Cylinder 2 Misfire or a Random Misfire
73: Cylinder 3 Misfire or a Random Misfire
74: Cylinder 4 Misfire or a Random Misfire
75: Cylinder 5 Misfire or a Random Misfire
76: Cylinder 6 Misfire or a Random Misfire
80: Exhaust Gas Recirculation
insufficient flow detected
86: ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90: Evaporative [FONT=inherit !important][FONT=inherit !important]Emission [/FONT][FONT=inherit !important]Control [/FONT][FONT=inherit !important]System[/FONT][/FONT]
leak detected in the fuel tank area
91: Fuel Tank Pressure Sensor
low input
92: Evaporative Emission Control System
insufficient purge flow
0: ECU
low input
also can someone look at my build thread and see if those plugs i could not identify are the o2 plugs.
