engine slight bogging
so recently the wagon started bogging a bit and hesitating to start and a bit while driving so i changed out the distributor cap rotor and wires plugs only had about 2k on them. did those changes and it still did the same thing.then i realized i kept having to fill the radiator with water every 3 days so i figured the head gasket was on its way out. now i have changed the head gasket starts up quick but im still having the issue with the bogging, but right now it only does it if i dont let the car warm up. when warm it doesnt do it as much maybe 2-3 times but still testing it out since i just finished the head gasket. does anyone have an idea on what it might be???? also no CEL
i would check ground wires and fuel too. could be a filter or a pump is psi isnt there
maybe unrelated but you could also jiggle the throttle cable, make sure nothing gummed up
