1986 honda wagovan help!
I was driving my wagon the other week and noticed when i got home it was cruising at an abnormally high speed about 20mph without pressing the gas. I park and and it jumps straight to 3k and will not go down, its not a pulsing idle it stays solid and when i cut the car of it starts to diesel and will not cut off unless i press the throttle to the floor. So far i have checked the float, choke, and throttle linkages and nothing is hung or stuck open. I didn't visually find any vacuum lines cracked or broken and the cel is not on. I tried to look in the sight glass to check the fuel flow but i am assuming since it is revved up that you don't get a proper reading because i can never seem to see anything in it even with adjusting the float screw. The only thing i have found that changed the way the car is running is to one: unplug the vacuum line on the dizzy or turn the dizzy but nothing else changes how it runs. could someone please give me some sort of advice to why this is happening?
