Starter Help....yes ive used the search bar...
So starter wont turn, so i searched...common things to check ive done. Grounds are clean, battery is supplying power to the starter. The main relay is fine (tested with a push start car fires right up) I connected power to the starter and it fires right up and car starts (using battery cable from battery to the little tab on the starter solenoid) That led me to believe there was something wrong telling the solenoid to engage. But where do i go from here? I dont want to be push starting and cable starting (battery cable from tab on solenoid to power) everywhere i go...any ideas where to go from here?
thanks
-Ken
thanks
-Ken
car
What part of your "ignition" is brand new? And what parts (OEM or aftermarket) did you use?
When you are diagnosing problems you can never assume that a new part is functioning; you MUST check and verify each part/step per FSM (yes helms) or you will form terrible habits diagnosing problems.
is brand new. Aftermarket (Napa) replaced due to i dont like sloppy keys. i followed helms without results. i bi-passed NSS, checked for clicking of MRH, listened for clicking of ignition when key is on the III, all seems normal. If starter was bad, correct me if i'm wrong, "Jumping it" (Direct power from outside source) would not turn the solenoid.
Check the Black/WHT wire coming from the 4P connecter off the ignition switch - that is the starter wire signal that goes from ignition switch, through NSS and to the starter. That is all there is in the system, pretty simple stuff. So: if you starter IS cranking (when you jump positive battery to solenoid) then its good.
If you are totally sure your ignition switch is good (that napa part said for automatic only, not sure whats up with that - worth looking into), then it has to be your neutral safety switch OR an open somewhere in between (on the black/white) source from the ignition to the starter (which includes the NSS).
sorry for the delay with 10h work days and working on my dads cars, and being a father my own cars fall short of attention. I believe somewhere there is a short, or bad ground or something between the starter 'noid and key. I removed the NSS switch and looped it (first thing i tried) i may just park it for winter soon and pull it back up next season
Weak! Fix it! Get out the multimeter and start checking continuity between the sections I mentioned above in my post. If you have a helms or OEM it'll me super easy to find out whats up. Your shit cranks with battery direct, you know its something dumb. Git r' done!
