Crankshaft Compatibility for the DOHC ZC
I recently bought a EF hatch for the ZC engine. Im going to rebuild it and am pretty sure the crank is F'd from spun bearing. To keep cost down from buying a new crank I need to know if any other crank will work since I have every D series crank sittin on my shelf. I have google searched but cant confirm if any other crank works with the ZC. Please let me know. Thanks
86-87 D16A1 has 22mm snout
88-89 D16A1 has 24mm snout
If it's the 24mm snout you can use a D16A6/Z6 SOHC ZC basically any D16 crank with the right size snout. The easiest to find is the A6 crank. If it's the 22mm snout crank, then find another DOHC ZC one or a 86-87 D16A1. Either way you got options.
