89 RT converted to 2wd
ok ive searched and found a little info,but need to know if the rear diff, axles are pulled out will this cause problems? confused. I am getting an rt without tranny all it has is drive shaft back (axles diff etc.) well if he keeps that stuff its really cheap but dont wanna get screwed if the rear will get messed up. Or pay alittl more just put a 2wd tranny in and take off drive shaft? Thanks in advance.
Tip: If you do leave the diff in replace the diff oil with the newer lower friction diff oils for 2 reasons.1)Probably has never been replaced.2)Your gas mileage(mpg) will go up.Old oil has probably thickened & newer oil is lower friction.
