Bad vibration while driving in gear in my rt4wd.
Feels like a rumble almost from what I can explain. I don't know if it is my drive shaft or what how can you check this issue? Is there a normal way on how to check what is wrong in the rear end or drive shaft on an rt4wd. Thank you.
1-80 on your trans and dif somtimes not always that can cause vibration
Most any parts store will carry front and rear axles for an RT4wd
Start at the transfer case flange and try to wiggle each joint all the way back. Check all your axles for play. Check rear differential input for play. Check wheel bearings at all four corners.
Good tips in the shakeing the joints around, need to do that.
BUT...Rockford Drivelines is (as far as I know) the only place in the country that measured the Civic RT4WD u-joints and manufactured replacements! They are $33.75 each, I hear you need 3 u-joints for a complete recondition. Check 'em out. There's another thread on this that specifies the part number you need to order, but if you go to their site it's pretty confusing...recommend calling them and talking to a rep to make sure they get it right.
