rt4wd clutch cable replacement part number?
I know the Honda replacement number but those are no longer available. I have been searching the web for a replacement but most the ones I find say exc. wagon. My local napa and oreillys say they are unavailable also. So my question is will a clutch cable from another civic work on my rt. and if you replaced yours wich one did you use and what's the part number. Thanks guys.
I did remove my current one and on the bushing that hooks to the tranny lever it says SH3.
That's the code for the hatchback right.
PIONEER Clutch/Cable CA-506. This is the brand name and part number I found. Auto Zone can get them. I got mine from finditparts.com, probably won't be here till Wednesday.
Here is a thought I had, do you guys think that using that shorter cable puts extra stress on the pedal assembly. In return causing all the broken clutch pedals. Maybe alot of people out there are running a shorter cable and don't know it. Just something I been thinking about, what do you guys think?
