Weird RT Problem with trans
Trans is in gear when shifter is in neutral. Putting in any gear causes it to lock up and not move. Is this possibly because shift fork slipped on shaft? I've seen this on VW aircooled trans, but never on any other Honda box. I was horsing around with friends and was doing a burnout in SL, went into wheel hop, then locked up and stopped. Put it in Neutral and found it to be stuck in a higher gear, (third, I think) drove home in neutral, but no amount of prying, etc will get it out of gear.
Will a standard EF transmission fit my RT if I change to a tube-type shifter assembly? RT transmissions are very rare here, and I've not been able to find one in a wrecking yard so far. The car had no drive shaft when I bought it, so it has no rear wheel drive to fight with the new 2-WD box if I have to do it this way.
Thanks for any help or suggestions you could give me,
Jesse
Jesse
