dohc zc distributor?
                    so i have a rt4wd and I got a dohc zc to drop in. one of the cables on the distributor is broken of from the sensor so I'm probably going to need a new distributor. Then on eBay I came across this distributor adapter to run a dohc zc in a civic/crx with out any wire cutting or adapting. I wasn't aware that I needed to do anything to the distributor for it to work on my civic. I tried doing a search but really didn't find anything on it and now I'm kind of confused. And so my question is has anyone here ever used something like this? Or recommend it to ease installation. Or what ever thoughts you have on this subject would be helpful. Below is a link to the eBay add, hope it works as I'm not a computer wiz. lol
:? http://www.ebay.com/itm/88-91-Honda-Civ ... 2884wt_149
As for rewiring provided you have an OBD0 ZC the only rewiring you need to do is to splice the cylinder position sensor plug onto the cylinder position sensor wires that go into the dizzy on the single cams. I forget the wire colors right now but a quick search on-line will tell you which ones. It looks to me like that's basically what that adapter harness does. It plugs in between your body harness and dizzy and splits those two wires off to the cps mounted on the exhaust cam.
Either way you'll still need to buy an 88-89 integra distributor or 88-91 ZC distributor which is a TD-03U
Good to know... I couldn't remember if my ZC Dizzy came with a square or round plug on it (I was the second person to put it in a USDM car so it may have already been swapped to round) but I knew the replacement Dizzy I bought had the square plug and I swapped my harness to the square plug to make things more strait forward with stock parts.
Yeah they have to be square plug because the Cam Sensor is located on the 2 pin connector for the cam sensor. Instead of being internal like the d16a6, therefore allowing the larger round plug.
