Stripped Intermediate Shaft Hole... What to do?
                    Was installing my transmission on my engine last night and I went to install the half shaft.  All bolts went in easy but when I went to torque them to spec the single bolt closest to the transmission just started to spin... you know that feeling...the one that makes you cringe.  So now I'm in a tough spot.... Do I just leave the bolt in there sorta engaged in the stripped threads, just take it out all together and run with two bolts and hope it's never a problem?  Or I guess the correct thing to do would be to repair the threads with a helicoil.  But i'm not digging the idea of spending $60 on a helicoil kit to make that happen.  I feel like the two remaining bolts which are the stacked ones should be plenty for daily driving but it makes me nervous.  What think y'all?
im sure a mechanic guru will chime in and have all the specs for you any second .. :roll:
