Ideas for stock looking turbo on rt
                    I've been thinking for a while about some ideas for a cheap, stock looking small turbo setup for my rt. Low boost about 4-7psi which isnt much but not looking to make big power on a6block and y8 head. just wake it up a little. Probably just going to tune with a VAFC and try to keep stock catback for real sleeper effect.
Plans:
Hf mainfold and heat shield with t3 or something small internal wastegate(would like full boost in low rpms)
Half radiator and side mount intercooler from saab or something mounted next to it
I would like to keep the stock air box and use stock piping from a OEM boosted car for the stock look
I feel like I will run out of room keeping the air box in the stock location
Problem with all this is there are not many/if any OEM boosted cars around north dakota. I have not seen any of the charge piping layouts for OEM turbo cars Any ideas are welcome and post up any setups you have seen would be nice.
Another question is about the o2 sensor on an Hf manifold, would I want to keep it where its at or move it to the down pipe? Or could I run a wideband sensor on the Hf manifold.
If this is a bad idea tell me know before I get my hopes up
                            Plans:
http://honda-tech.com/showthread.php?t=1755395
