Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 117
  1. #51
    Wagonist
    Join Date
    Sep 2009
    Location
    Franklin, TN
    Posts
    250
    Very cool! A lot of work but it will be well worth it.
    89 Blue RT Auto
    All stock
    DaPics!
  2. #52
    New Wagonist
    Join Date
    Jun 2012
    Location
    Auckland
    Posts
    55
    Very Nice ! After my auto swap, i had to connect the 2 heavy gauge black wires that were going to the auto shifter so it thinks its in park to start, Also had to drill a clutch hole.
    Sort out a plate with a hole for the shifter, to cover the hole where the manual shifter comes up. (use the one from the parts car i guess)
    If you find your battery going flat over about 2 days, and it makes a click when you disconnect the battery, just remove one of the wires on the ignition barrel (by itself on the side) Something to do with needing the key in to move the shifter i think. (was a drain on the brakelight/hazard fuse i think for that, you'll find the one, it'll click again when you disconnect it etc) like a solenoid click.
    Also found it easiest to drop the whole steering column down from the dash to get the pedals in.
  3. #53
    Moderator superhatch's Avatar
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Some new parts arriving.
    Once it warms up I'll get cracking on putting everything in. Right now my garage floor has 2 A6's, a B16A2 block, Z6 head and manual trans hanging out. I need to purge! lol
    "It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
    My Wagon Blog
    My Civic Si Blog
  4. #54
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Parts are coming in slowly. Header should be here today and that's the last piece I need to get the install going.
    Cleaned the engine bay this weekend:
    I'm moving in a different direction though. After some thought I've decided to build an NA Z6. In the short term I'll be putting in the stock A6 as I'm getting the Z6 built. I should be getting the car back together in the next few weeks. I swapped out the manual transmission cables and took out the AT shifter so progress is being made!
    My Wagon Blog
    My Civic Si Blog
  5. #55
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Header arrived!
    My Wagon Blog
    My Civic Si Blog
  6. #56
    council member BillBoard's Avatar
    Join Date
    Aug 2006
    Location
    Denver CO
    Posts
    3,571
    holy moly... loving the progress!!
    @billdirects
  7. #57
    Wagonist
    Join Date
    Sep 2009
    Location
    Franklin, TN
    Posts
    250
    That is a wild looking header! Wonder how much heat that baby is going to put in the engine compartment? You going to wrap it? Good job on the build, SH!
    89 Blue RT Auto
    All stock
    DaPics!
  8. #58
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Quote Originally Posted by arries289 View Post
    I haven't thought about wrapping it yet. I ran a Bisimoto header in my last wagon and head never seemed to be an issue that I could tell. I thought that maybe this one would work with the RT trans but I think it's going to hit a little. It comes unflanged so re-welding shouldn't be too much work. But I've got to get the exhaust custom welded to work with the RT body, and weld up the high flow cat so I'm sure I'll end up paying a grip for all the exhaust welding I need done.
    My Wagon Blog
    My Civic Si Blog
  9. #59
    Band Wagon
    Join Date
    Mar 2016
    Location
    California
    Posts
    15
    This wagon is crazy clean I just wish my damn front end lined up properly on mine lol
  10. #60
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Of note...the HKS exhaust needs a LOT of modification to fit. For the most part I used the axle back and the resonator and then used 2.25" piping for the rest of the run. The Hatchback version doesn't work at all for the RT for a variety of reasons. Even the way the muffler sits is different between the two models.
    My Wagon Blog
    My Civic Si Blog
  11. #61
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Quote Originally Posted by Shwagoneer View Post
    Thanks! That credit really goes to @Billboard for keeping it so clean. It needs a little body work near the rear arches but I'm hopefully putting my own touches on the wagon so that I can consider the torch passed from Bill to me soon.
    My Wagon Blog
    My Civic Si Blog
  12. #62
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Pics of some stuff.
    Tires have been chosen:
    http://www.autocross.us/forums/topic...ires-for-2016/
    My Wagon Blog
    My Civic Si Blog
  13. #63
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    I took off the lower panel to drop the steering wheel and get at the pedals and I couldn't deal with the alarm and cruise wiring. While I was there I decided to cut the fog light wiring too and re-run everything. I'm a bit anal about wiring.
    My Wagon Blog
    My Civic Si Blog
  14. #64
    Wagonist
    Join Date
    Sep 2009
    Location
    Franklin, TN
    Posts
    250
    Yeah, that is pretty ugly!!
    89 Blue RT Auto
    All stock
    DaPics!
  15. #65
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    It was all zip-tied up somewhat cleanly...but the cruise control module didn't work and you can't get the modules anymore. I don't really need an alarm and so it was just a lot of extra wiring in the engine bay and under the dash that I wanted to get rid of.
    My Wagon Blog
    My Civic Si Blog
  16. #66
    Join Date
    Aug 2006
    Location
    Denver CO
    Posts
    3,571
    I worked really hard on wiring those fog lights. lols. However I cannot take credit for the rest of the mess. I like what you got going on here.
    Sadly the Cruise control never worked for me either
    @billdirects
  17. #67
    Wagonist
    Join Date
    Jan 2013
    Location
    Murfreesboro, Tn
    Posts
    232
    Love the build man! Like were this car is going now! POWER WAGON!
  18. #68
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Quote Originally Posted by BillBoard View Post
    The fog light wiring was good actually, I especially appreciated the fuse block taps you used for power! Once the Z6 goes in I'll be using a Rywire engine bay harness and so I just wanted to streamline all the wiring in the bay regardless. I also got a new set of fogs which have a little less wear on them.
    The cruise had some module in the engine bay and then the brain tucked under the dash. I looked around on Ebay for a while and couldn't find a replacement for either with the original brand name so I just decided to pull it and reduce some of the clutter in the bay.
    My Wagon Blog
    My Civic Si Blog
  19. #69
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    I hemmed and hawed over what pedals to get and in the end just decided on a new set of OEM pedals for now. Repainted the arms and I might try and get a stiffer spring for the gas pedal to help give it some more feedback.
    My Wagon Blog
    My Civic Si Blog
  20. #70
    Wagonist
    Join Date
    Jan 2013
    Location
    Murfreesboro, Tn
    Posts
    232
    Quote Originally Posted by superhatch View Post
    Where can I get OEM pedals? I need new ones for both of my cars hah.
    I like the idea on the stiffer gas pedal spring, would like some feedback on that once you do it.
  21. #71
    Moderator Haydz's Avatar
    Join Date
    Dec 2005
    Location
    Auckland
    Posts
    5,482
    You may want to strengthen the pivot point and surrounding area for the clutch pedal - it is known to break at the welds and flex meaning only partial clutch movement.
  22. #72
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Quote Originally Posted by Haydz View Post
    A friend just mentioned that to me! Were gonna take it in to the shop and weld it up next week.
    On another note, might be some delay in the project.
    Picking this up on Saturday:
    myatadv.blogspot.com
    My Wagon Blog
    My Civic Si Blog
  23. #73
    Wagonist
    Join Date
    Jul 2007
    Posts
    100
    You are going to love the RE-71R! Those tires are still the fastest street tire on the market for autox. I am currently running them and love them!
  24. #74
    Join Date
    Sep 2007
    Location
    Wisconsin
    Posts
    1,214
    Quote Originally Posted by Mo-Van View Post
    Awesome! I've read nothing but good stuff about them. I think last year 80% of the street class winners had them on. lol
    My Wagon Blog
    My Civic Si Blog
  25. #75
    Wagonist
    Join Date
    Sep 2009
    Location
    Franklin, TN
    Posts
    250
    SH, I need you to forget about that bike and get back on that Wagon! NO DISTRACTIONS ALLOWED!!
    89 Blue RT Auto
    All stock
    DaPics!
Similar Threads
  1. "Born to Roll"
    By OddMarz in forum Rides & Builds- Civic wagons
    Last Post: 04-22-2016, 04:16 AM
  2. Have you seen Born To Race?
    By FSC4wd in forum General Civic Wagon Discussion
    Last Post: 09-19-2011, 09:15 PM
  3. 1st-Born Child is Here! Pics Inside!
    By B18C5-EH2 in forum The Lounge
    Last Post: 09-14-2008, 07:48 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
