88 Wagovan AWD
 danwagonboy
                Band Wagon
danwagonboy
                Band Wagon
                    I'm new to this group and just wanted to see if anyone can figure out what's going on with my ride.  The pictures aren't too detailed, but if anyone could figure out the car's purpose, it would be here.
Good work man. I love stuff like this!
I bow before your fabrication skills and determination.... To merely have the idea "wouldn't a twin engined wagon be cool" is easy but to make it happen is heroic....
I wanna see some donut vids! 'Specially if you get that rear-steer going (or crab walking would be cool too - paralell parking made easy!)... ooh ooh or front engine in Reverse and rear in Drive burnout....
(Sorry - after all your time and effort the first thing I wanna see is you abuse the snot outta the car :twisted: :oops: )
i want to see videos too.
The blue wagon was my daily driver for years at this point, and the donor 1991 civic was purchased for $250 from some shady characters in Salinas.
Trying to fit the donor subframe in the blue hole
nice fabrication procedures for keeping the chassis straight.
I tip my cap off to you.
One concern right now is that I'm going to use it to commute for a while and while 20 mpg isn't bad compared to an explorer, I would rather be near the old mpgs (28-30). Keep in mind their both automatics. One thing I just tracked down yesterday is that even though the rear ecu was getting a vss signal (same switch as the front), it didn't know D4 was selected so the rear lockup torque converter was never engaging. My hopes are that it will increase highway mpg slightly. I may also have a slight case of ODO error in that the wheels/tires have a bigger rolling radius than stock.
The obvious solution to the bigger problem is to take the back engine out and run it on the front, but that would make it sit high in the rear and would be no fun to drive. My question now is whether it would be feasible to either adapt some type of locking hub to the rear or get at the innards of the transmission and make some way to pull the differential apart. Its possible to put a external pump on the transmission but I think this would cost more energy than if it was simply disconnected at the shaft. Any input is appreciated.
