Brake backing plate questions
Hi all,
I've got a few questions regarding the rear backing plates on our wagons with drum brakes. When changing out my brake shoes, we noticed the brake backing plate on the rear passenger side of my wagon was torn and a big chunk of it was missing.
1. Are they interchangeable from 2wd to rt4wd wagons as well as from year to year?
2. Do hatches and sedans have these brake backing plates and if they did, would they work in my rt4wd wagon? (from a part # search on hondaautomotiveparts.com, I'm thinking they aren't as I didn't see that part listed.)
3. Are these backing plates available from any of the auto parts stores? I guess no.
Thanks in advance!
James
Thanks in advance!
James
Thanks turbo_teg! Let me know!
Ok, sounds like a plan. I'm hoping these backing plates work fine but good to know you may have them... just in case!! Thanks again!
The 88-00 Civics all use the same rear drums and shoes. ANd hubs and bearings and all the stuff in them. However, the actaul spindle, though bolts to all trailing arms...has two differenet bolt patterns for the 4 bolts that bolt the spindle to the drum's backing plate. Why, no one knows. So within the 88-00 Civics, there are two, Not sure which has which. just random crap I found out.
