I just got CREAMED
lol well i just bought this EE2 last night. It drives ok needs a little work to be perfect. Im not gonna drive it for a while anyway. Its a 89 and its auto
any way here are the pic's
only rust i see so far.
to do list.
Get a new auto transmission
possibly a new motor since this one has 293k
brakes
front seats
fix rear seat
fix the little rust it has
clean interior
will add to list as i go along.
COST
Wagon-$700
Registration-$250
D15b2 replacement-$40
D15z1-replacement-$300
Auto-->manual swap-$200
obd0 dpfi-->obd1mpfi wiring conversion-$160
obd0-->obd1-$70
new/used distributor-$80
fuel rail-$15
ecu-$60
tune up stuff-$35
tow when tranny locked up-$75
replacement hf tranny $150
payed friend to help with swap x3 since it was my first time -$200
total so far= $2265
to do list.
brakes
front seats
fix rear seat
clean interior
COST
Wagon-$700
Registration-$250
obd0-->obd1-$70
fuel rail-$15
ecu-$60
tune up stuff-$35
total so far= $2265
good luck & keep us posted .....
Save the wagons!
and how do i tell if my thermostat is bad?
The t stat is connected to the upper part of the lower radiator hose. Right where it connects to the back of the block. You can put it in a pot of boiling water with a thermometer, and see if it opens. Hope this helps
for cleaning that filter...
Looks like a distributor coil?
http://www.rotawheels.com/wheels.asp?wheelid=14
GL!! = )
pics later.
the wheels I plan on using for daily driving, just need to find 1 more wheel I let some one barrow it and they didnt return it. I will never do that again.
my DA front shocks ant struts. will these work on the wagon?
the Motor i bought for $40.00
looks like a party to me...
H*LLYEAH !!!
yea i'm running a set on my ride and there's another wagonist that has some too... check out the June voting of the PAC's
i took the end caps off and hooked them both up the the battery and sure enough the fan kicked on.
where do they go? i dont just want to wire it direct to the battery.
i also found that my left corner has a hole in it.
