My feeble attempt at making some extended top hats
So I have been seeing a lot of top hats being made and decided I need to make some. I want to lower the front and rear of my wagon a little more and need the extra travel as this is my daily driver. So far I only did the fronts. All I need to do now is paint them and put the studs back in. Let me know what you think.
Thanks bam. I could have done a better job with them. My next set should be cleaner than these.
1 1/2 sch 40.
Thanks for the compliment. I just spray painted them real quick.
Yessir! I've got some good action shots on the lathe and what not.
Here is a pic of them right after I sandblasted them. I finished up the welds and sand blasted out the imperfections.
Here is a pic of them painted, I used a anti-rust paint. I went with red because it was on sale at Advanced Auto, and it matches my GC's
They are a work in progress still, and this is my first fab/weld job. So what do you think?
Thanks man. They ride good. I need to replace the inner tie rod (has some play) and make some for the rear. Then lower the car some more and see how it really feels.
(100th post)
