CREEK! very loud and embarassing
The story:
when my wheel left or right i get a loud CREEEEEK from the driver side front. I also get it going over bumps at low speeds. It's quite loud, it has gotten a lot worse over the last week.
initially i thought it was the upper control arm bushings, i had someone giggle the wheel and it sure sounds like it's coming from directly behind the hub not from up high in the shock tower. i know my hearing is shot but not that shot. anyone else ever had a problem like this before i start randomly replacing stuff. I jacked the car up and took the wheel off to see if i could narrow it down, the noise stops when there is no load on it so it was pretty much a waste of time.
THANK YOU!!! keep my 464,000km work-horse running.
you are probably right, thanks.
...always loud & embarassing...
:shock:
powerwashed anything lately?
lube that sh@#2t...
....now i need to replace my front strut bushings.....
