Loose/Banging Rear End
1st..No perverted comments on the Subject :-P
Only had my Wago a few days but today I was driving her and it keeps making this clunk/bang in the rear end..mostly from the drivers side rear.
I can shake the wheel and I hear a clunk when I do so..I had my Bro look while shook the tire and he states it Looks like a bushing is worn..Hmm..
Ball Joint? Wheel Bearing?
I will have it up on the jack 2morrow and see what the deal is..
Any comments/experience with this is appreciated!
also check rear strut, coil spring in rear strut
happy hunting and best of luck
just summin' up...
So your telling me the rear shock/mounts...did I get that right? LOL
I will be getting it in the garage in a bit...and checking..also the trailing arm....
Now...If we just build this giant wooden badger....
According to the Haynes manual it was the Panhard Rod. Sometime in the past it had broken at the bushing area and was re-welded, but the bushing bolt was not tight.
REALLY need new shocks,,driver rear has been bleeding bad for a while..
Cheers
